Fuel Lean code, Supercharger
Old Aug 13, 2008 | 11:27 AM
matyellott's Avatar
matyellott
Default Fuel Lean code, Supercharger
Guys just had my 2006 Gt dyno'ed (446 to the wheels), during the process the techs noticed that my Fuel air ratio was unusally lean, so I had the gt500 pump installed. today I got the following code (fuelsystem too lean bank , OBD(?) system check not complete) after the gt500 pump install my air fuel was exactly where it was supposed to be. I have a procharger running with only tune adjustment being to the fuel pump after install. Any ideas
Old Aug 13, 2008 | 04:32 PM
SCCAGT's Avatar
SCCAGT
Fuel system too lean, bank 1 and/or 2 code usually means a vaccuum leak of some sort. As long as the A/F ratio is where it needs to be while in boost (low 12-high 11s) look for disconnected hoses.
Old Aug 13, 2008 | 04:40 PM
matyellott's Avatar
matyellott
Will do i am also going to clean my MAf when I get home, hopefully this will help. To clean the MAF i disconnet the negative battery lead, remove the sensor spray with maf clean replace and reconnect the battery correct?
Old Aug 13, 2008 | 06:05 PM
matyellott's Avatar
matyellott
Cool
I just opened the hood, where the heck is the MAF with a procheregr installed?
Jb145700
Aug 21, 2022 06:37 AM
Gene K
Oct 21, 2015 11:37 PM
firecoyote
Sep 27, 2015 02:37 PM
TfcCDR
Sep 14, 2015 12:08 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
