Difference between comp stage II NSR cams?
Old Sep 1, 2008 | 01:22 AM
Blue07GT's Avatar
Blue07GT
Default Difference between comp stage II NSR cams?
What is the difference between the N/A stage II NSR and the Stage II NSR for F/I and supercharger applications.
If you go the the F/I stage II with the plan on eventually putting on a supercharger in the future, are you going to loose anything while being N/A?
Or if you go with the N/A cams, is something going to fail with the cams if you put a S/C on the car in the future?
I'm just up in the air on what route i want to go with my stang, i do KNOW i'm going with a set of shorty headers, one piece drive shaft. And i have the cash to do a set of cams along with those mods.
Help is greatly needed, lol.
Old Sep 1, 2008 | 01:34 AM
06Saleen3V's Avatar
06Saleen3V
You will not gain near as much power with a blower cam on an NA application...however, if you decide to go with the NA cam, you will be fine with a blower up until about 8psi, 10psi is pushing it...NA cams have more overlap so allow for more gains up top...however, more overlap can bleed boost on high boost applications...hope that helps
Old Sep 1, 2008 | 01:36 AM
06Saleen3V's Avatar
06Saleen3V
My suggestion is to do the NA cams, and when you eventually get your blower, run 8psi. You will see around 450rwhp...anything after that you can run nitrous if you build the lower end. This way you can enjoy the power of the cams while NA and continue to enjoy the lopey sound after you get your blower.
Old Sep 1, 2008 | 09:26 AM
abarker8541's Avatar
abarker8541
^^^^ knows what he is talking about. Stick with the the N/A cams then when you get your blower just buy a blower cam. you are already spending lots of money so just get some cams with it.
Old Sep 1, 2008 | 09:29 AM
SSFenris's Avatar
SSFenris
agreed. I have a buddy with blower cams on his N/A (juiced) 2V... I walk all over him on the track (I have VT's Stage II N/A cams), but I'm planning on boost later (to the tune of 22#), and will be getting a set of VT's Stage III S/C cams. It's all about right tool for the right job.
uberstang1
Dec 7, 2017 07:10 AM
Luke9222
Oct 22, 2015 11:55 PM
uberstang1
Sep 20, 2015 06:42 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
Luke9222
Sep 4, 2015 06:46 AM
