Whipple Install Started
Old Nov 30, 2008 | 08:16 PM
  #21
Diabolical!'s Avatar
Diabolical!
Yellow sucks. My brother had a hood for his 3000GT delivered by them and they tried to leave while he was inspecting it because they knew it was damaged. When did whipple switch to yellow? When I got mine in January, it came FedEx freight.
Old Nov 30, 2008 | 08:26 PM
  #22
hammeron's Avatar
hammeron
i'm pretty sure mine came fed ex also....i
sure feel bad for these folks, who have to
worry if their whipple is going to show
up or get lost
Old Nov 30, 2008 | 10:35 PM
  #23
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Congrats Bruce! Glad its all coming to realization and you will feel the power soon!!!!
Old Nov 30, 2008 | 10:56 PM
  #24
BruceH's Avatar
BruceH
Learn it yourself. I'm done.
Last edited by BruceH; Nov 13, 2010 at 11:26 AM. Reason: Learn it yourself. I'm done.
Old Dec 1, 2008 | 12:02 AM
  #25
sailing220's Avatar
sailing220
What is this "Yellow transport" everybody is talking about?
Old Dec 1, 2008 | 01:48 AM
  #26
Daryl06's Avatar
Daryl06
Mine fuel lines go around the back underneath. Haven't noticed any difference.What tune are you going to use Because I also have a nonintercooled kit and would like to see how this kit does. tnx
Old Dec 1, 2008 | 08:01 AM
  #27
sevenleaf's Avatar
sevenleaf
Originally Posted by BruceH
Yellow transport was supposed to deliver the whipple today anytime from 9-6. Guess what? They didn't show up. Stayed home the whole day.
Nine inch nail: So what are the big boost kits on fordracingparts.com all about then? I assumed they contained all the parts shown.
Wow man sorry to hear that!!! I'm crossing my fingers they have all the parts in the box for you ,waiting is just the worst part.
Congrats on the blower!
Old Dec 1, 2008 | 08:09 AM
  #28
CobraO's Avatar
CobraO
Yellow showed up this afternoon. I got 5 hours on it today.
A few questions:
The manual says to route the fuel rail line over the sc. It would look alot better routed behind. How has everyone done it?
I decided to use a bit of high temp rtv to hold the gasket on, after seeing the sqeeze out after torquing I'm having regrets. Anyone else use it instead of a more traditional way to hold the gasket in place?
The manual says to torque the timing cover bolts common to the alternator mounts to 37 ft lbs then 90 degrees. I just torqued them to 25 ft lbs same as the alternator. 37 + 90 would surely strip out the bosses in the block. This has to be a typo. Anyone do the 37 + 90 degrees?
In all a productive day. I was able to get torques on all fasteners and a neighbor brought over his calibrated torque wrench so I could see how mine compared. Mine were fine. Couldn't order the procal tool because my vin is already registered on the site. I'll call them first thing.
Thanks for the support. It is appreciated.
That fuel line fits under the blower near the rear, look down the side of the blower and you will see what I mean. Highlighted green in this picture.
I followed the torque instructions, but I doubt I got to 90 degrees, maybe 45 degrees past the required torque. No problems.
Used a very tiny bit of gasket seal, just to hold the gasket in place while installing the blower. Took two people, no way I could have done it myself (bad back).
Old Dec 1, 2008 | 03:18 PM
  #29
MadMike1337's Avatar
MadMike1337
post a video when its all said and done!
Old Dec 1, 2008 | 06:27 PM
  #30
moosestang's Avatar
moosestang
I torqued to whatever the manual said. I used the online manual, which seems to have been deleted. Hammeron, where'd that pdf file go? I don't think I did a full 90 degrees though.
The fuel crossover hose goes under the blower. I used gasket cinch just like the manual stated. I still have a whole can of it.
Yellow didn't deliver my blower, they kept it at their warehouse until I came and got it though. yellow sucks *****! When I finally tracked it down, they wanted to deliver it 4 days later. It was an hour away from me, so I said I'd come and get it. I think it depends on where you live as to what deliver method is used. I got mine back in August of 07
