Shifter moving noticably
Old Feb 19, 2009 | 09:50 AM
clfrye's Avatar
clfrye
Default Shifter moving noticably
My shifter has recently starting moving, noticably, when I hit bumps lately. Any ideas on what might be causing this?
Old Feb 19, 2009 | 10:09 AM
hammeron's Avatar
hammeron
there is a place where the transmission is
attached through a rubber bushing (a cross
member) and then to the underside of the car
body. i would check this connection to see if
the bolt has loosened or if there is more play in
the bushing then should be there.
Old Feb 20, 2009 | 10:34 AM
157dB's Avatar
157dB
Cut & Paste Expert
Or replace the worn out OEM shifter bushings with quality Poly bushings.
The "Hydro" engine mounts dont help any either.
Old Feb 20, 2009 | 01:52 PM
bigray327's Avatar
bigray327
A little play is normal when going over bumps, considering the squishy engine mounts and the urethane transmission mounts.
I have Prothane engine mounts, a K-member brace, torque limiters, and an MGW shifter... it doesn't move a millimeter now!
carid
Jul 8, 2016 09:55 AM
Boostaddict
2.3L Eco-Boost Tech
Nov 24, 2015 06:11 AM
jc409
Convertible Tech
Sep 24, 2015 03:38 PM
jstrothe
Sep 24, 2015 12:17 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
