Might be running rich, need someont to help verify...
03-03-2009, 01:45 PM
possible... solution he much call bama
03-03-2009, 04:02 PM
How lean will the motor run before an DTC is thrown?
03-04-2009, 01:33 AM
enough for the knock sensors to be kicking in... what the stoichometric number is IDK???
03-04-2009, 07:34 AM
Quote:
Originally Posted by
acascianelli
40% either side (lean or rich)
03-06-2009, 11:42 AM
Multi-Tasking Moderator!
07musclemustang
yeah popping and detonating is lean
call bama bro
I jumped the gun on my response and agree 100% on what you wrote
OP let us know what happens!
03-06-2009, 12:54 PM
Another new symptom...
It doesn't do it every time I start it, but sometimes on a cold start it will rev up to 2000-2200rpm for a little bit.
03-06-2009, 01:15 PM
LEAN, you need to get it fixed bro. The longer you wait the more your engine is getting fu#ked up. Running to lean leads to much bigger problems.
03-06-2009, 01:42 PM
Let me clarify the exhaust noises; it's not so much a popping, more of a gurgling.
03-06-2009, 01:55 PM
Cold start high rev is totally normal...as long as it eventually drops down. It's kind of like a "choke" from the old school days.
03-06-2009, 02:40 PM
Have you checked for a vacuum leak in the intake/hose, etc?
