fuel pressure gauge with whipple 2.3
I use the aeroforce interceptor gauge to read fuel pressure. I had an electrical fuel pressure gauge with the sender T'd into the fuel crossover hose that goes through the blower. I didn't like having the sender laying there on the engine and it was one more place for a possible leak, so i ditched it.
hey there jimmymustang, options sure are
limited for us whipple users.
i'm not gonna recommend any way in particular, i'll
just show what i did. it's been fine for a couple of
years now, but you should do what you feel comfortable
with...
good luck and let us know how it turns out....
http://home.comcast.net/~cookpaging/...t2/gauges.html
with...
Thanks for the pics, that is probably the way I am going to go. Did you use teflon tape on the fittings or another? Is teflon safe with gas? Another option could be a new fuel rail, check out Fore Precision Fuel Rails. They have a second tap further up forward up the rail. They are pricey, and I still dont know if they would have enough clearance for the sender. Any other rails that come to mind that might work? THANKS Jim
I put a 'T' in the fuel line and it would leak after about three months. I got tired of replacing the fuel line and the dangerous leaking fuel so I went with Aeromotive fuel rails and SS braided fuel lines. Here is pic of my setup.
foxtrot
09-29-2015 06:32 AM
