My thoughts exactly. Lift one of the battery leads for about 20-30 minutes to reset the adaptive learning. You do not need to reload the tune after that. Simply reloading just the tune does not reset all of the parameters that are causing the return to a less aggressive engine response.
Hell yeah, i will have to try this after my last final today =).. So it will never do that adaptive learning crap again? or is this just a temp fix like re tuning it?
Originally Posted by 157db
+2
+2
+2
Hmm really?! I guess it does work- i will try later.
I have the same problem at low RPM with Brenspeed tune. Power is great after 3k but until then the car is anemic. I'm going to try a VMP tune hoping that will cure the weak low-end. I had good experiences with Justin's tunes before. Some 4.10 gears would solve the low-end problem too, but I'm considering going to twinscrew in the future and need to save some cash until then.
What is a VMP tune? I see in your sig you have the glass roof option. Do you leave the cover open most of the time? Are you glad you got it?
vmptuning.com
Glad I got the glass roof, pretty cool. The glass cannot be removed. There's a shade you can pull to cover the glass from the inside, but I never use it.
