Brake Issues/Question
Old May 5, 2009 | 10:05 PM
sailing220's Avatar
sailing220
Default Brake Issues/Question
Hello everybody,
My right rear rotor is being gouged by something (brake pad?) and I'm currently waiting for new rotors and pads in the mail (excuse to upgrade, whoo!).
Am I OK removing the pad from just the right rear brake assembly in order to stop the (quite noisy) destruction of the rotor?
Old May 6, 2009 | 12:06 AM
Cobrakev's Avatar
Cobrakev
I would say no. It will still push the pistons out during the brake application. the piston would then be pushing against the rotor.
Old May 6, 2009 | 07:54 PM
2007VistaBlueGT's Avatar
2007VistaBlueGT
NO! If you remove the pads the caliper piston will come out of the bore, you'll lose all your fluid and most likely crash because you'll have no brakes.
Old May 7, 2009 | 04:07 PM
157dB's Avatar
157dB
Cut & Paste Expert
NO.
Dont drive it if you must use the brakes.
The rotor is probably beyond resurfacing....
Brembo sells mean replacement OEM style
rotors that are nicely priced.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
