Bamachips rev limit
When I received my tunes from Doug, my rev limiter was set at 6496 RPMS on all four tunes. I switch back and forth between the race and tq tune on the street, but I like the tq tune at the track as that tune usually gives me .2 to .3 sec faster than the race tune each and every time.
pretty sure Doug sets it at 6800, you can ask him to make it any number you want. the stock motor will not make that much more power above 6300 or so IIRC. you can also adjust the limiter on the hand held tuner. IMHO set the limiter 300 or so above where u want to pull the gear
When I was stock with Steed UDP as my only mod, my best 1/8 was around 9.4. Don't remember my trap. With the 91tq/JLT my best was around 8.8. With 91tq/JLT, 4.10s, upper,lower control arms best time was around 8.69. 4.10s make the car a little hard to launch with street tires, especially having smaller tires 25.6" diameter.
7000 is possible, but I wouldnt do it, the valve train is not set up for those RPM and the rods probably would not like it. Also in stock form the car will not make power up there anyway
We just started using HP tuner on my 05 GT to play around and we turned off all the ford baby sitter stuff, moved redline up to 6750. Something we noticed in the code was in the stock ECU ford keeps the throttle plate at 40% open below 2750RPM regardless of your foot so we adjusted that out of the car. Next we removed the settings for the throttle going 100% closed between shift regardless of your foot and opened the intake butterflys sooner in the RPM band. We have for now left the AF stuff alone and timing as I run out the rest of the 87 octane but pretty soon we will tune it for a CL intake on a wideband and see how much more the car picks up. What I notice now is much improve throttle response and the added RPM on redline does drastically improve your fall back RPM on speed shifts. Seat of the pants the car feels like it picked up a .2 or so and probably 1 - 2 mph in the 1/4 mile.
I will keep you all posted but so far so good.
I think Doug has mine set at 6500 on mine (93 tq).
I am reminded of "way back" when I bought my first PC. Bought the 450MHz CPU, got it home and Windows says 448MHz!! You got screwed out of 4 RPMs dude!!
I think most of these guys that have it set so high (6800) are not actually revving that high; they are just making sure that they can rev a bit past 6k without having the computer mess with timing in preparation for hitting the limiter.
