Got run off the road and slammed my rear passenger wheel into the curb. Ran the car on a lift at about 50 mph and you can see the entire hub/wheel wobbling in and out.
Geeeeez, run off the road ?? Holy Crap man, Don't stop there..... By who ???... Why????
Is everyone ok ??
I recently had the same issue. Only my axle was slightly bent and couldn't feel it while driving down the road. However, the left rear (the bent axle) brake caliper would heat up so much that it chewed up the outer brake pad and would make an awfull squealing noise. I went with a stock replacement axle. Most of your aftermarket heavy duty axles ( I only know of the Moser axles) will require new over sized studs due to the larger holes in the flanges. Also most of these axles have a thinner flange and require modifications to your brake caliper. Advise- stock replacements, drive defensively, and never ever let your wife take the mustang. I also ended up with a slightly bent rim which needed to be straightened out.
