which supercharger?saleen vs paxton
#41
I have 4.10's with the Saleen on their one size smaller than stock pulley, putting 470 to the tire. You need good tires to make it hook (I run 305/45/18 Mikeys), but yeah, it's a very good choice. Never liked the looks of centris, they make the underhood look cluttered. Here's a pic of how mine looks (mind you, it's a super shaker).
https://mustangforums.com/forum/memb...installed.html
Note the stock 7 psi Saleen Supercharger has 3.8X pulley.
#42
#43
Installing the V3
I installed the V3 non-cooled kit over Memorial Day weekend. I also installed the CMDP and 160 degree thermostat at the same time.
The kit came with the AIT relocation kit. I soldered all my connections and used shrink tube on the wires. I took my time and made sure that all the wires were covered with wire looms and the hoses were fit nicely.
Do not forget that if you are doing the AIT relocate that you need to get a 3/8-18 NPT (nominal pipe thread) tap at a hardware store and use a 9/16 progressive drill bit (use Teflon paste).
Make sure that you measure all wire to be soldered before actually solder it. The power steering relocate was a big pain to get it fitted right (tight around the wiring) and draining the power steering fluid was a pain. Remember that if you are trimming the hoses to exact length to think about what will be in the path before you cut it.
You definitely want to get ratchet box end wrenches for mounting the S/C to the mounting plate. Make sure that you torque the bolt to the right values. The install guide is void of this information. You can get it off the web.
It will take you at least two full days to do the install if you are being meticulous and taking your time. If you have someone to help, it will go faster.
This is by far the best mod you will make for the money!
#44
Long tubes yes, cams no. This graph was before the super shaker, I should have "a little" more now.....and it's a Dynojet, if you're on a Mustang dyno, expect 10% higher on a Dynojet.
#45
I agree with the Whipple over the Saleen....by far. Procharger over Paxton? NO. I did the research because I thought the same thing, I fell in love with the sloppy loud noise of the procharger, but it doesn't make the power that a Paxton can first of all, and second of all they are not nearly at DRIVABLE. I called Brenspeed, the best mustang tuner in the United States right now and they won't even tune for a Procharger because of the drivability issues. I did my extensive research before I dropped all that money trust me, and on top of that I thought the same thing. I wanted the procharger over the paxton, but after a month of research....Paxton is the way to go. And the vacuum release on the Paxton is my NO MEANS quiet. It has a great sound at idle and cruise speeds, people that know anything about cars know you have something nasty under the hood. Good luck with whatever you choose tho! As far as twin screw, the whipple is one hundred times better than the saleen. You crank a saleen to 19 psi and it's gonna be cryin that it can't handle it....on the other hand, the whipple will push 20 psi no problem...much for room to work with in the future.
#47
From what i have heard on paxton supercharger reviews is that they have to be repaired regularly. I wanted a paxton at one point but almost everyone had the same review. Most of them stated that they had repair issues with very low miles, but also stated was it made amazing power when it worked properly. But all in all form the reviews there were more unsatisfied paxton owners than satisfied.
#48
well i only have about a thousand miles on mine so far, but so far so good....where are you seeing all these "bad" reviews from? could you copy and paste some of the sites, I would like to read some of what you are talking about so I can be aware of some the these "issues" and know to look for certain things..
#49
I have not heard of any persistent issues with the Paxton before. I have however, heard of random issues with virtually every system on the market. Its safe to assume when looking around on the internet that it is far more common for people with problems to be sounding off. How often do you see posts of people saying things like "Hey guys, just wanted to let you know my car is working perfectly. kthxbye"
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mungodrums
09-28-2015 10:54 PM
