need help! what cai inake, steeda or c & l street
i need some input, i am going to purchase a cai and flash tuner. i dont know a lot about this , but i like the steeda , or the c & l street. is there a difference with the hp gain between the two. also i am thinking breenspeed for the flash tuner. any input or suggestions would be appreciatied.
thanks bryan
thanks bryan
From what I've learned and read there is very little difference. Brenspeed sells a packaged cai and tuner, check with them. Or try vmptuning.com or bamachips. All 3 are good to deal with from everything I've heard. But if you add the cai you must get a tune.
As far as tuning goes,
I like Bamachips tuning, from the fact they will modify the tune free of charge, even if you buy something from somewhere else.
I like Brenspeed, but they charge you for every revision, if you buy from somewhere else. If you buy from them, then the changes are free.
All CAI benefits are comparable. If you go to a C&L Racer 95mm and a Airaid 101mm, those might be overkill for a NA setup.
no difference between the two power wise... like pitch said, brenspeed or bamachips... both very reputable tuners... (not saying vmp isnt, just havent delt with em)
i have the steeda and its a kick in the a$$ with the bama tune... is your car an automatic?
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
09-24-2015 09:18 PM
