So my Paxton Novi 2200...
gets delivered on Tuesday of next week. I truly can not wait, since this is the first boosted car Im expecting to put down 400+ at the tire. Its like waiting for Christmas Day to come as a kid again.
I do have a few questions for you gurus out there that you might be able to answer:
1. Ive heard conflicting numbers on what is "safe" to run on a stock block and tranny. 420/450/450? Ive also heard that torque is what kills trannies and motors too.
2. What is optimal injector duty cycle for the 39lb injectors along with the KB BAP?
3. What target A/F ration should I be reaching safely for during the dyno pulls?
4. I heard that if you drive under 3 grand all the time its like basically driving a non boosted car since its a centri? Is this true? This car is my daily and I drive about 5 miles into work each day and somedays never hit a redline.
Basically I bought the kit from Brenspeed, and im getting it installed at a shop Ive trusted for many years. So Im trying to educate myself enough to know what to look for. I hate going into something completely ignorant, so Ill ask a lot of questions.
Many agree that 450 RWHP is a "safe number" for stock internals. If running slicks then I would worry about the trannie and the neck snapping TQ when using slicks
Just like stated above 95% or less at WOT.....the lower the duty cycle the better (even at WOT)
at WOT anywhere from 11.3-11.7 depending on many other factors. 11.5 is about spot on for FI....I was at 10.9 and pig rich....now at 11.2-11.5 and gained HP and resolved start issues with the tune
regardless of what type of S/C you wont make boost unless WOT (not exactly cause at 50% + throttle you will make some boost) but overall you wont be in boost unless you call upon it and cruising or just going thru the gears you wont be in boost for the most part. (normal everyday driving)
Your tune will have spec parameters that are met every time you go WOT....if your not WOT your adaptive learning can and will adj to your driving....so if it feels different (raging bull most the time when first installed) and over time it seems more sluggish or slower when cruising/norm acceleration then its the adaptive learning just adj to your driving habits. This can be reset with a simple battery disconnect for 15+ mins.....and no you dont have to reload the tune after you do a disconnect.
The idle might be erratic after but the car will adj and adapt to that after a few start ups...... this is my exp and from what I read that I feel is fact.
hope it helps....and anyone correct me if I am wrong or off in my advice
You can go all the way to redline without any indication of it being supercharged. It's all in the % of throttle you give it. That goes for all superchargers and turbos. They all use some kind of system to bleed off boost until you stomp on it.
ernesto-619
09-10-2015 01:32 AM
