s197 auto tranny?
#21
Source?
It's actually 550 ft/lbs, hence the 55 in the name - but that's AFTER torque multiplication of the TC. If your engine makes that much, you'll be going way over the rating.
Here's what 5R55S stands for: 5R55S (5speed, Rear drive 550 tq rating multiplied @ converter) Short ratio
#23
3rd gear syncros and converter...really? did you swap the syncro with an upgraded part or just a new part from ford.
#24
There is no synchro gear for 3rd in a 5R55S. It uses a servo not a synchro.
I'm betting he just upgraded the converter.
I have upgraded servos (billett) installed from Level 10 in my transmission.
Synchro gears are used in manual trannies.
#25
Hey Zkiller,
After you upgraded the internal weak spots and I assume the input shaft as well, how has the transmission functioned? Does it change drivability at all? What is the stall on your transmission? I'm curious to know since I may switch over to an auto eventually and will either put in a 5R55S or a 4R70W.
I know the 4r70 can be built to hold 1000 hp, you can put a trans brake in it, reverse manual or just have it shift itself. It all depends on how it's built from what I've heard.
#26
Hey Zkiller,
#27
Plenty of stock motor stangs have the stock at go as well as FI cars. Its a crap shoot. You have to pay to play!
treesloth
09-28-2015 07:03 AM
05, 5r55s, automatic, ford, gt, horsepower, maximum, mustang, rating, s197, supercharger, torque, tranny, transmission, vortech
