Factoryt Mustang GT Exhaust?
Old 12-14-2009, 08:42 PM
V8s_Are_Great
V8s_Are_Great's Avatar
Default Factoryt Mustang GT Exhaust?
All righty, so, looking to buy a 2006 Mustang GT. The previous owner added a BBK intake and what looks like the SLP axle-back exhaust. I'm trying to find a factory Mustang exhaust picture or diagram to compare with this vehicle. I'm fairly certain more work has been done, but I can't be sure what until I get it on a lift. Any help?
V8s_Are_Great is offline
Old 12-14-2009, 09:50 PM
bluovalguy
bluovalguy's Avatar
Look in the S197 classifed section. There are quite a few guys selling factory exhaust that have pictures of them.
bluovalguy is offline
Old 12-14-2009, 09:54 PM
bluovalguy
bluovalguy's Avatar
https://mustangforums.com/forum/s197...-mufflers.html
There are some pics of some.
Old 12-14-2009, 09:56 PM
dragrace4fun80
dragrace4fun80's Avatar
Yeah, I should actually sell mine, since I have completely replaced it now. You will have a single welded piece, consisting of downtubes from the manifold collectors, H-pipe, cats, and continued tubing that lock into the middle section of the car's tubing. From there, it continues as two singe-piece tubes over the axle, connected to the downtubes which are welded to the exhaust (axle-back pieces) and the exiting pipes. Once again, these assemblies are all welded.
dragrace4fun80 is offline
Old 12-15-2009, 06:34 AM
V8s_Are_Great
All right, so I should only be seeing a single set of cats? That's really my biggest concern since I'm moving to Virginia and have to pass emissions(?)
Old 12-15-2009, 09:52 AM
sailing220
sailing220's Avatar
There are 2 cats on the GT, one on each side.
sailing220 is offline
Old 12-15-2009, 10:03 AM
Nuke
Nuke's Avatar
+1
1 cat per bank of cylinders, both exit to an H-pipe (stock) or an X unless the previous owner did a drastic exhaust change.
FYI, the stock exhaust flows well. Any changes from the H or X on back will only change the sound. No performance gains are to be had with axlebacks or catbacks.
Nuke is offline
Old 12-15-2009, 11:48 PM
V8s_Are_Great
Yep, checked it out today on the lift. Catalyst and O2 sensors are still where they should be. The PO eliminated pretty much anything downstream of that. I'll need to look again the see if he removed the H/X fitting, but I seem to remember it being straight pipe all the way back.
I am vaguely familiar with the workings of an H or X fitting on an exhaust system. How does it stack up against larger diameter 'straight' pipes?
Old 12-16-2009, 09:52 AM
jodadejss06gt
jodadejss06gt's Avatar
V8's, let me know if you need anything, I have the stock H pipe with cats. I also have the stock GT mufflers and am located in VA!
jodadejss06gt is offline
Old 12-16-2009, 10:03 AM
Nuke
Nuke's Avatar
There's a write-up in the Exhaust Sticky regarding the H and X pipe vs. straight pipes. The X or H are for the purpose of balancing out some of the pressure spikes.
Nuke is offline
Quick Reply: Factoryt Mustang GT Exhaust?
