Blew the motor - pics to come
Old Jan 10, 2010 | 02:13 AM
Intervention's Avatar
Intervention
Originally Posted by rustic2169
So before I start with how it happened, I will explain how I'm set up. I have an '06 Mustang GT with a full BMR tubular steel suspension in the rear, hurst short throw shifter and a Saleen Stage 3 S/C package from Brenspeed. I have ran this set up for a year now but I am new to the blown scene.
Originally Posted by foolio2k4
I have yet to hear of anyone blowing their motor that is NA. Pretty much all are from boosted engines that last a year or a little longer.
More info would be great. Thanks.
Reading is key
Sorry to hear about your motor. In the end, just gives you a excuse for more HP
Old Jan 10, 2010 | 03:01 AM
sailing220's Avatar
sailing220
GT500 Pump > BAP
Old Jan 10, 2010 | 03:04 AM
blackS197's Avatar
blackS197
High gear high speeds full throttle = too much load = boom.
mashing on it at 140 did the job. Its tons of more load on the engine then mashing on it in 2nd gear......
Old Jan 10, 2010 | 07:20 AM
rustic2169's Avatar
rustic2169
My kit is tuned for 9.5 psi. The kit also came with the BAP and not the dual pumps. The power is around 445rwhp est from what I've seen from others on here pushing and what Brenspeed told me.
Old Jan 10, 2010 | 07:23 AM
rustic2169's Avatar
rustic2169
Originally Posted by cobra443
The BAP is suppose to be set to full rich at all times, its never suppose to be adjusted. With a stg 3 saleen you should have had the GT500 pumps....
I was set to 30 on the BAP on the lean side, but this was what Brenspeed told me they have been able to run safely. Now, this was my first winter with an S/C and it was about 30 degrees or less out so I know I just ran too lean.
Old Jan 10, 2010 | 07:26 AM
rustic2169's Avatar
rustic2169
Originally Posted by Riptide
Man I envy you guys who have the money to just fix it right away when you blow an engine. I'd have to save for two years before I could afford to buy a built motor.
Trust me, I didn't have the money to do this. I had to take out a loan which the bank applied to what I owe on the car so I was able to refinance and make lower payments than what I make now. I also have had to move other funds I have around and I'll tell you now, I'm fully tapped.
Old Jan 10, 2010 | 08:33 AM
cobra443's Avatar
cobra443
When I installed my BAP it stated on the instructions to leave it set to full rich. Did they specifically tell you to set it there, or that it 'should" be safe. Also the weather played a role in this I'm sure, along with the serious load on the engine at that speed.
Old Jan 10, 2010 | 09:18 AM
def67's Avatar
def67
pics?
Not that I can help just want to see pics.
If you need a new motor wouldn't it be cheaper to find a new/used car and use your super charger on it, assuming its not damaged?
Old Jan 10, 2010 | 10:24 AM
Starfire's Avatar
Starfire
First time I've seen a stage 3 from Brenspeed blow an engine. I'm driving mine in the winter, but I stay outta boost when it's cold and also running a 91 octane tune, with 93 octane gas, figure less timing is better in the cold.
Good luck with the new engine!
Old Jan 10, 2010 | 10:29 AM
Diabolical!'s Avatar
Diabolical!
I think you nailed it, bro. Sub freezing temps and running lean on boost will cook a motor. Thanks for sharing, sorry it happened.
