Autometer DPSS Shift Light Install
Old Jan 12, 2010 | 07:18 PM
ladder31's Avatar
ladder31
Default Autometer DPSS Shift Light Install
im installing autometers new digital shift light and i cant find the tach signal wire. anyone know where and what color it is?
Old Jan 13, 2010 | 06:26 AM
07 GT E UPP's Avatar
07 GT E UPP
Hey there Ladder, hope you also bought the required Autometer " Adptor Box " (Part # 9117)
to properly hook up your DPSS Shift Light. This is nessessary (except "Raptor" light) for the Distribturless
Ignition System on our 2005 - 2009 mustangs. Gray wire is Tach/Shift Light signal. Costs around $ 75.00.
See detailed installation instructions below, and hope this helps..
Installation Information
6/11/2007 2005+ Up Ford Mustang: Auto Meter DIS TACH ADAPTER (#9117) Installation
Now that the Battery is Disconnected, let's get started:
1. Remove the lid off of the power distribution box, located in the front passenger side corner of the engine bay.
Trying to install an Auto Meter tachometer or shift light in your 05 or newer Ford Mustang and aren't sure where to start? Check out this write up by our Tech Department! We've broken down the installation of the necessary Auto Meter DIS Tach Adapter #9117 into a step by step procedure that will help get you on the road/track faster!
Important! First things first, after you open the hood, Disconnect one of the battery terminals before moving on with the rest of the install!
2. Remove the thick power wire from the power distribution box, using a 10mm socket.
3. Using the release tabs at the front and rear of the power distribution box, you can simply lift the box up (when releasing those plastic tabs at the front and rear).
4. The green covered harness connector is the last connector towards the rear of the box. To remove this connector to make it easy to work with, use a 7mm socket and unthread the last bolt inside the top of the power distribution box. The bolt will not come out, but will release the connector.
5. Remove the green plastic cover, simply by unsnapping the locking tabs.
6. You are looking for the twin red wires coming from port C5. Note: Some '06 and 07+ models will have these wires one port down (using photo as reference) in location D5 instead. The individual ports are not individually numbered. The letters are cast into the bottom facing edge of the white plastic connector, and the numbers are also cast into the bottom edge of the white plastic connector, going long-ways. These are hard to see, but they are there.
7. Cut the twin red wires about 1 or 2 inches down from the connector. Twist the cut ends from the connector side together and connect to the solid red of the Auto Meter 9117 tachometer adapter.
8. Twist the cut ends at the harness side together, and connect to the red/green of the Auto Meter 9117 tachometer adapter.
9.You may ground the black tachometer adapter wire at the top of the radiator core support nearby where there are already factory ground wires.
10. Carefully route your new adapter wires and mount your 9117 adapter. Re-assemble in the reverse order. Be careful not to pinch your new adapter wires during re-assembly.
11. You may mount the adapter, using self tapping screws on the wheel house, between the power distribution box and fender.
12. The gray wire of the adapter will provide you with a good useable, V8 tachometer signal.
13. The adapter is now installed, follow the instructions provided with your Auto Meter tachometer or shift light to complete the installation. When you've finished the mounting and wiring for the tach or shift light, check all connections and assemblies to ensure that everything is correct. Re-connect your battery and start engine to check for proper operation of product.
djbigskrilla
Sep 20, 2022 01:04 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
kdryan
Aug 21, 2015 04:01 PM
Soldier GT
12
Aug 20, 2015 09:42 AM
jjwinel78
Aug 17, 2015 03:34 PM
