weird noise in cold
weird noise in cold
Hey guys i have a 2009 mustang gt with 9,000 miles and am in jersey so you know it has been very cold. The first time i start the car in the morning the engine is making a weird sound almost like a washer machine. it is very distinct. it seems to only be happening the first time you start the car in the morning. im not sure what it could be.. belt..pully?
thanks
thanks
I'm in Jersey, too. On a cold start up mine sounds kind of like a diesel engine for a few minutes,( cackling, ticking sound), then as it warms up, it gets quieter. Its just the valvetrain noise, I wouldn't worry about it (If the noise you're hearing is the one I described).
The only strange noise I've have seems to have been fixed by replacing the FEAD idler pulley. TSB details are below. It didn't sound like a washing machine, but more like a whistle, like a train or kettle.
COLD START FEAD HOOT—WHISTLE NOISE / BUILT
BEFORE 1/28/2008
TSB 08-4-2
FORD:
LINCOLN:
2007-2008 Mustang, Expedition, 2007-2008 Mark LT, Navigator
Explorer Sport Trac, Explorer, F-150, F-150
MERCURY:
2007-2008 Mountaineer
ISSUE OPERATION
DESCRIPTION TIME
080402A 2007-2008 Mustang 4.6L: 0.3 Hr.
Some 2007-2008 F-150, Mustang vehicles equipped
Replace FEAD Idler Pulley
with a 4.6L and 5.4L engine; 2007-2008 Mark LT,
Includes Time To Remove
Expedition, Navigator vehicles equipped with a 5.4L
And Install Serpentine Belt
engine; Explorer, Mountaineer, Explorer Sport Trac
(Do Not Use With 8678A,
vehicles with 4.6L engine and built before 1/28/08,
8620F)
may exhibit a front end accessory drive (FEAD)
080402A 2007-2008 F-150/Mark LT 0.3 Hr.
related high-pitched metallic whistle/hoot noise after
4.6L/5.4L: Replace FEAD
a cold soak in ambient temperatures below 40 °F
Idler Pulley Includes Time
(4.4 °C). This noise may be caused by the grooved
To Remove And Install
nylon FEAD idler pulley.
Serpentine Belt (Do Not
ACTION Use With 8678A, 8620F)
Follow the Service Procedure steps to correct the 080402A 2007-2008 0.4 Hr.
condition. Expedition/Navigator:
SERVICE PROCEDURE
NOTE
FEAD IDLER PULLEY NOISE MAY BE MOST
8620F)
APPARENT AT OR NEAR COLD ENGINE IDLE
080402A 2007-2008
0.4 Hr.
SPEEDS (APPROXIMATELY 1200 RPM). NOISE
Explorer/Mountaineer/
DURATION IS LESS THAN 10 MINUTES AFTER
Sport Trac 4.6L: Replace
STARTUP AND WILL BE ELIMINATED WITH
FEAD Idler Pulley Includes
FEAD BELT REMOVED.
Time To Remove And
Install Serpentine Belt (Do
1.
Replace the nylon FEAD idler pulley, refer to
Not Use With 8678A,
Workshop Manual, Section 303-05.
8620F)
PART NUMBER PART NAME
6L3Z-6C348-A Idler Pulley
DEALER CODING
CONDITION
BASIC PART NO. CODE
6C348 42
WARRANTY STATUS:
Eligible Under Provisions Of
New Vehicle Limited
Warranty Coverage
IMPORTANT: Warranty
coverage limits/policies are
not altered by a TSB.
Warranty coverage limits
are determined by the
identified causal part.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do
the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper
vehicle service. The procedures should not be performed by “do-it-yourselfers”. Do not assume that a condition described affects your car or truck. Contact a
Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation
determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article.The information in this Technical Service Bulletin
(TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates.The most recent information is
available through Ford Motor Company’s on-line technical resources.
Copyright ã 2008 Ford Motor Company Online Publication Date February 7, 2008
PAGE 1
BEFORE 1/28/2008
TSB 08-4-2
FORD:
LINCOLN:
MERCURY:
ISSUE OPERATION
DESCRIPTION TIME
8620F)
SERVICE PROCEDURE
NOTE
8620F)
080402A 2007-2008
0.4 Hr.
FEAD BELT REMOVED.
Time To Remove And
1.
Not Use With 8678A,
8620F)
DEALER CODING
CONDITION
BASIC PART NO. CODE
6C348 42
WARRANTY STATUS:
New Vehicle Limited
Warranty Coverage
IMPORTANT: Warranty
PAGE 1
KingRando
10-02-2015 08:06 AM
mungodrums
09-28-2015 10:54 PM
