P0113 Code - Need Help
Old Feb 6, 2010 | 07:47 AM
Jersey Stang's Avatar
Jersey Stang
If you're looking to purchase a new MAF wiring harness, let me know where you get it. A few days ago, someone pulled so hard on my CAI that it ripped out the wire from the temp sensor. I get the same P0113 code and it won't go away. i'd like to just replace the whole harness and start fresh.
Old Feb 6, 2010 | 09:00 AM
S197steve's Avatar
S197steve
Sorry to hear that man, I'll keep you posted on my fix... I'm hoping I can just solder a wire or something and be ok, but if not I'll see where I can get the MAF wiring harness.
Old Feb 6, 2010 | 09:03 AM
Jersey Stang
The guy pulled so hard on it that it broke the solder. Then the wire was too short so I had to use a three inch wire, soldered on both ends. For some reason its not working, I think it would be best to just start over.
Old Feb 6, 2010 | 02:52 PM
157dB's Avatar
157dB
Cut & Paste Expert
Here is the DTC troubleshooting chart...
Here are the 4.6L motor wiring diagrams
Old Mar 6, 2011 | 07:06 AM
wayne613's Avatar
wayne613
I just get my shiznat out of the shop, 2 days later, *bam*, this code pops up this morning getting coffee.
Likely a butterfingers move on the tech with the harness putting it back together. Have to check later, otherwise I´m going to have to buy a new MAF sensor. Lame.
Old Mar 6, 2011 | 04:54 PM
wayne613's Avatar
wayne613
Guessing it has to be the temp sensor in the MAF sensor housing then..No wiring issues, or bent pins that I could see.
So...Any recommendations for the replacement? Just find an OEM, or go with something like this? Considering it´s N/A, with no plans to do otherwise in the near future, would this help at all with getting a bit more out of just a JLT CAI?
Old Mar 8, 2011 | 11:34 PM
wayne613's Avatar
wayne613
Since the birds were a chirpin´...
Autozone, $110 (+$50 core charge) OEM refurb replacement. No code re-appearance yet.
Thought maybe that´d fix the original canned tune leanness issue with my Bama-tune for my CAI, and perhaps the RPM dipping when coasting sometimes. But no dice. I got a new one from them which works, but considering how many of these get put out, I believe it likely something off with my chit.
Did I not clean the throttle-body thoroughly enough, could this be the issue? Something has to be up, damned if I know what it is though.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
