shaft masters now advertizing direct bolt in aluminum d/s no adapter needed!
Need some help.
I'm in the middle of installing my shaftmasters direct bolt and I'm having some problems. It didn't come with any instructions at all. The problem I'm having is at the axle. They provided 6 hex bolts, to be used on the pinion plate I assume, but you can't get a hex bit in to torque them down because the u-joint is in the way. From what I read in Taco Bills post (he installed a similar ds but with an adapter) you reuse the 4 bolts from the trani output. A little difficult to Torq, but not like the back ones. Has anyone else installed this and if so how do you tighten and torq the rear u-joint plate to the axle pinion?
http://i36.photobucket.com/albums/e1...S/IMG_2470.jpg
Haven't installed mine yet (nor received it) but it looks like those 6 hex are for an adapter plate not used on that setup. I can only imagine to use the same bolts that came off the old DS. Also call shaftmasters I can only imagine they would be very helpful.
I will say this...doing the DS and the hurst at the same time is the way to go! Made the hurst part A LOT easier!
How easy is it to install? I was wondering if I should try to do it myself or pay to have someone do it. I am not very experienced. The only thing I have ever done is put a cai on and replaced the alternator on my 2006.
Urambo Tauro
08-27-2015 10:53 AM
Figure8allday
08-22-2015 11:11 AM
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
