Separator oil pic.
Just think, without the seperater that crap is going into you intake, onto the intake valves and into the combustion chamber and burned.
Just look up "Hemi oil separator catch can by Moroso" It has reusable twin filters and a drain valve plus you can take it fully apart for cleaning.You'll have to buy your own fittings and hose as the the stuff they supply is well.......crap!
I have the steeda unit which comes with useless parts too so you have to go Napa to get proper parts but it does really work. It has the clear bottle so you can really see all the oil your catching. I empty mine every 500 miles.
patrick
patrick
Like wise, the Moroso Inter Cooler battery tray tank I installed came with 5/8th's hose fittings and the Kenne Bell uses 3/4 Hose. The stock tank which I will probably pull off has the exact fittings I needed but I wasn't sure I could remove it and just use the Moroso as the only fill tank. Back to the oil catch can, I used the one that came with the Kenne Bell but the plug in the bottom is leaking all the time. I'm looking for a replacement and was curious what everyone is using. They have some on Ebay for 18 to 30 bucks but I wasn't sure if they were worth it.
What useless parts are you talking about?
breaking
10-02-2015 01:27 PM
