Spark Plug Issue?
Old 04-20-2010, 02:01 PM
candymanjl
candymanjl's Avatar
I switched to full synthetic after about 7,000 miles. I used the same weight as stock, Walmart had it in stock and it's cheap there.
candymanjl is offline
Old 04-20-2010, 02:46 PM
Lifter583
Lifter583's Avatar
I run Amsoil and it goes for 10 k before a change...which is early for their recommendations...as for the discolor on the plugs...the factory did use a type of anti-seize and with carbon build up they do look very strange.
Lifter583 is offline
Old 04-20-2010, 04:11 PM
moosestang
moosestang's Avatar
Is this the rust you speak of?
It's not rust, it's combustion byproduct. Who knows what they are putting in this gas.
moosestang is offline
Old 04-20-2010, 04:25 PM
Swervin309
Swervin309's Avatar
I bought the car brand spakin' new. Had 5 or 6 miles on it. Since then i've babied it. Oil change every 5k, cleaned the filter (K&N) ever 10k, check fluids frequently. I never really rode it hard until i moved to Atlanta.
Moosestang, that's exactly what it is. Combustion by-product? I'm going to assume that the combustion chamber looks similar. Is there any way to prevent this build-up? Is there a way to clean this crap short of pulling the heads?
Thanks for the oil advice. Pardon my inexperience with these newer engines. I had a 69 Stang coupe with a 351W that i knew inside and out. These aluminum/OHC/fuel injected/computer controlled jobs are new to me.
Swervin309 is offline
Old 04-20-2010, 04:27 PM
simplexdesign
simplexdesign's Avatar
What kind of gas do you run in the car?
simplexdesign is offline
Old 04-20-2010, 04:32 PM
Swervin309
Swervin309's Avatar
Either Kroger or Quick Trip. I used Chevron for about 35k but in Atlanta Kroger and QT are cheaper. Cheaper more than likely being the problem.
Old 04-20-2010, 05:28 PM
moosestang
moosestang's Avatar
I use mostly BP or exxon. Seafoam can clean anything. I've been meaning to get a can and run it through the tank. You can also feed it directly into the intake through a vacuum hose.
Old 04-20-2010, 07:33 PM
Swervin309
Swervin309's Avatar
I've heard of this stuff before. Got a buddy here that swears by it. There's a $h!t load of vids on YouTube of people using it. I'll give it a try. Thanks a mil.
Old 04-20-2010, 09:51 PM
candymanjl
candymanjl's Avatar
E85 is in almost all fuels and it's very corrosive, eating fuel lines and ruining lots of parts. that's why the mustang's gas cap has a no E85 symbol on it. unfortunately we can't avoid it completely since it's in everything. not that I know for sure that's what's making the plugs look like that but that's my guess.
Old 04-21-2010, 07:11 AM
Swervin309
Swervin309's Avatar
Makes sense. Every pump you see now-a-days has the "may contain up to 10% Ethanol" label. Why can't hippies leave my gas alone?
Quick Reply: Spark Plug Issue?
