SEAFOAM TIME
Old May 5, 2010 | 04:55 PM
  #21
Swervin309's Avatar
Swervin309
Originally Posted by ski
Nice detective work.
That's how i found a broken valve spring on a 351W in a 69 coupe. I miss that old push-rod hung of iron.
Old May 6, 2010 | 08:04 PM
  #22
The_Enforcer's Avatar
The_Enforcer
so is there any point to pourin a bottle of seafoam into a full tank of gas, each of you has a different opinion. also do you need to change ur oil or plugs after?
Old May 6, 2010 | 08:40 PM
  #23
jahudso2's Avatar
jahudso2
You only need to change your oil if you pour the seafoam into the crank case. I seafoamed my car yesterday because I am planning to change my plugs and I want to eliminate as much carbon on the plugs as possible. I sucked about 1/3 of the 16 ounce can into the intake through a vacuum line and then put the other 2/3s into the gas tank. She smoked pretty good, so I hope at least some of the carbon was broken up. I'll try the plug change this weekend.
Old May 7, 2010 | 09:41 AM
  #24
ski's Avatar
ski
Using Seafoam in the tank may also eliminate a pinging problem that cannot be resolved thru other means(using different gas, etc.). Been there, done that.
Old May 23, 2010 | 12:24 AM
  #25
Stang9946's Avatar
Stang9946
How long after you seafoam should you change the oil? I'm pulling mine out of hibernation this week. No sense for me to put new oil in, seafoam and then have to change it again shortly down that road. That's just a waste. The oil that's in it now has been in it since last October with only 1,500 miles on it. Mobil 1 full synthetic. I ran it for 10-15 mins once a week all winter. What do you think?
Old May 23, 2010 | 09:34 AM
  #26
157dB's Avatar
157dB
Cut & Paste Expert
500 miles or so.
But, oil gets contaminated with combustion by products
(1500 miles is still not low enough to prevent oil contamination)
and this causes acids to form over time that can pit bearing journals.
You really should have changed the oil BEFORE you stored
her for the winter.
15-20 mins of running does nothing but pull more moisture out
of the air during the cooling down period after running the engine.
And does little to exaporate the moisture thats currently in the oil.
Its best to just let the motor sit with a battery tender and nice clean
fresh new oil in her. during storage.
Old May 23, 2010 | 05:16 PM
  #27
Stang9946's Avatar
Stang9946
Nvm, i figured it out
mungodrums
Oct 7, 2015 04:01 AM
clowe1965
Carolina Regional Chapter
34
Sep 28, 2015 09:18 PM
TfcCDR
Sep 14, 2015 12:08 PM
Sep 8, 2015 11:50 AM
