Need help on CHE LCA Brackets
Check out the pic. This is on the driver's side. Is this how the bracket is supposed to seat up to the mounting location?? Well if it is I gotta relocate the holes on the CHE bracket....
I can't make heads or tails of that picture but I've installed the C.H.E. brackets a few times, they are fairly simple and slide over the factory mounting bracket. What exactly is the issue you're having.
Holes aren't lining up on the driver's side bracket. I'm wondering if the flange on the rear part of the car where the relocation bracket goes is supposed to fit inside the bracket or just sit on top of the relocation bracket
