BAP Hookup on Saleen Supercharger
Guys,
I have a 2005 GT with a Saleen Supercharger and I want to buy a Kenne Bell Boost-A-Pump to upgrade my system using a 3.4 pulley.
I am currectly running with a 3.6 pulley and use my stock fuel pump.
Where do I hook up the Boost Pressure Switch from a Kenne Bell Boost-A-Pump on my Saleen Supercharger?
Since the switch is electrical and not a vacuum line, where does the sensor go with my application?
I know that some guys simply twist the two wired together to give the BAP a full time operation but if I wanted to only use it during boost, what is the best way to go.
You comments and advice is always appreciated. Dave
The best way to install the BAP is to solder the two lines together. This way the boost switch is always on and ready. I cut the two wires close to the base and soldered them there. This is the recommended install by Brenspeed.
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mungodrums
09-28-2015 10:54 PM
