Bad vibration in rear?!
Have a 2005 GT and every time i get to 50-55 mph i get a bad vibration and as soon as i get to 56 mph it goes away. Then you can slightly feel it at 80 mph. I don't even know where to start with what could be causing it
Has it been lowered? Pinion or Camber angle on the Drive Shaft. I just went through the same thing with my 08 GT.
Waiting for my new Adjustable Panhard Bar.
stand behind the vehicle and look at both rear tires. See if you can tell if one tire sticks out further than the other in realtion to the body/fender. I never noticed it until I had a Blue Collar Performance install my D-Specs.
Something to look at anyhow.
+1 on the RoadForce balance. It will identify tire and wheel problems that a standard balance will attempt to balance out (and fail). After the balance, then go from there.
Also, if you have aftermarket wheels, be sure the clips on any of the wheel studs are removed. They were installed on some of the studs during assembly and are unneccessary. They prevent aftermarket wheels from sitting flush.
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
