jack stand positioning
Old Oct 21, 2010 | 08:27 PM
6-Speed's Avatar
6-Speed
Originally Posted by Cobra Drifter
Nice ramps! Wish I could do that but my front splitter is about 3.75" off the ground. It would hit the second level of boards
The second level is only 3" ... your wheels should lift on the first level before the spoiler hits the third step which is 4.5" high.
Old Oct 21, 2010 | 08:29 PM
6-Speed's Avatar
6-Speed
Originally Posted by VRFlip
What is that red handled tool in the picture for?
It's an oil filter wrench ... the best type I use. Works great for loosening those tight OEM filters.
Old Oct 22, 2010 | 08:34 AM
157dB's Avatar
157dB
Cut & Paste Expert
If you go to searching for them on Google, you might want to call them
'Oil Filter Pliers' in order to find them...
Channel Lock Oil Filter Pliers - $12
https://mustangforums.com/forum/2005...rong-spot.html
https://mustangforums.com/forum/2005...n-at-rear.html
https://mustangforums.com/forum/2005...p-the-car.html
https://mustangforums.com/forum/2005...loor-jack.html
https://mustangforums.com/forum/2005...ack-point.html
A custom 'jack pad' that fits into the holes on the subframe is a very handy item to have...
Attached Thumbnails jack stand positioning-jacking.jpg   jack stand positioning-jacking2.jpg   jack stand positioning-jackspot.jpg   jack stand positioning-mustangjackpoints.jpg
Old Oct 31, 2010 | 08:16 AM
Frankobates's Avatar
Frankobates
While I understand it is important to jack the vehicle up properly, I have not been able to come across anything that will attach to a floor jack allowing the use of the factory jacking points of which appear to only be used for lifting the vehicle off the ground with a lift.
Old Nov 2, 2010 | 01:04 PM
Vapour Trails's Avatar
Vapour Trails
It could have been me asking this question a couple years back so I'll try and help for future reference.
You can jack by the:
K-member (front or side)
Frame rails (inside of the plastic moulding you will find a 2-3" lip that runs along side of the car)
LCA mounts on the body (they have a reinforced hump)
Pumpkin
I have used all of these locations without incident.
Jackstands can be placed at those same locations. There are a lot of options for raising the car.
mtgldr
Feb 3, 2024 09:00 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Sep 17, 2015 07:57 PM
TfcCDR
Sep 14, 2015 12:08 PM
