clutch
What is the real problem? There is air trapped in the slave now from boiling the fluid. You can try to get it out by following the factory recommended bleed procedure. You may want to take the tools with you to bleed the clutch at the track. After a pass, perform a couple bleed cycles and get back in line. We have found this to cut the problem in �.
funny! Do you work at Auto Alliance in the repair department with many techs and engineers? I would probably know you then! Without having the system bled, you will not get all the air out, which will eventually fail. Mine failed twice in three months doing exactly what you are suggesting, not to mention I've seen hundreds of mustang clutch, and tranny changes at work, and we wont even start a car without it bled from our machine. Hard to argue with someone who has spent 10-12 hrs 5-7 days a week for the last 6 yrs driving v-6's,gt's, and shelbys. lol
"vacuum pull" Is that your weenie pump? Can't help you with that one! Sorry, I was just looking for a good recomendation for labor. Since, I don't have the means to properly do it myself. I guess everyone knows more then the next guy on these forums.
junior04
Sep 28, 2015 10:53 AM
ccdguy
Sep 19, 2015 05:20 PM
