Foglight HID's
Actually, it's more related to functionality, IMO. The higher you go in degrees K, the less useable light. Fog lights are designed to aid during conditions of low visibility in dark conditions (snow, rain, fog...). The lower temps provide added contrast which aid in being able to define the edges of the roads, dividing lines, etc under those poor conditions. If you've ever driven in conditions where you found yourself in the oncoming lane and had no idea that you were there you'd understand.
I make this analogy: fog lights that look good and match your headlights are fashionable but not functional, much like a woman in a pair of stiletto heels; she may look damn good in them and drive you insane when you have her bent over and are hammering her from behind but she can't walk for chit in them in the least bit of snow.
i disagree a lot with your fog light opinion. if you live in an area that is more rural where you drive where there are lots of animals that happen out in the road and there are no lights other than yours around fogs are most certainly functional if there is no fog. they make it much easier for me to see anyway. fog hater
I'm actually a fog lover when used correctly (like the woman in stilettos bent over) as opposed to incorrectly (the same woman in stilettos in a snow storm).
Thanks. I will contact him and see what he can do for me. I like how with the fogs on I get a little more light output, but I don't want to be rude to other drivers. Hopefully the combination of capping and covers will do the trick.
I think 6k looks nice. 8k is way to blue but 5k is a little too white/yellowish. I'm not trying to look rice so I think 6k is a good medium. A little bluish but I think with my all black car it looks nice.
I won't argue the use of fogs out in da' boonies but those that run with them on using 6000K or higher and higher-than-normal wattage on crowded streets are simply asking for a meeting of their fogs with a baseball bat.
Around 5000k you're just getting out of the pure white and entering those frequencies that include blue tones. As the driver of the car, I'm sure it appeals to you. But as you pass the 5000K point, the light to the on-looker becomes irritating. The "warmer" colors of the more typical OE lamps which are in the 3500k range invoke less eye strain to on-coming traffic. People that flash you are doing so not just because of intensity (although the useable light output drops as you go cooler with the 'higher' K-values) but also because of the irritation from the appearance. Fog lights were never meant to "match" headlights. Again, function over fashion; stilettos for the bedroom and boots for the rugged outdoors. At least my g/f gets it...
Get these.
They have the housings as well as the bulbs
and the housings/reflectors actually match the bulbs that are included.
You cannot compare incadescent filiment bulb wattage to HID wattage.
Its LUMENS that you want to compare when talking about actual light output.
HIDs are more efficent that incandescent bulbs. It takes less watts with a
HID bulb/ballasts to produce the same lumens as an incandescent bulb.
