Electronics issues..
Old May 4, 2011 | 06:18 PM
Allstar's Avatar
Allstar
Default Electronics issues..
When I turn the car on it takes a few seconds for the dash to light up. Also the Time is always going back to 12:00 PM and the HID's wont turn on.. Now I know I need a new battery as this one is definitely bad but could this be the reason why my HIDs haven't been working and for the weird issues with the dash?
Does that make sense?
Old May 4, 2011 | 08:05 PM
SpartaPerformance's Avatar
SpartaPerformance
If you know you need a new battery and your having issues with electronics..... 1 + 1 = 2
Old May 5, 2011 | 07:07 AM
Nuke's Avatar
Nuke
These S197's (and most other cars these days) are very persnickity about voltage. Add to that the S197's poor record with the OE MotorCrap battery and alternator degradation/failure and you have a recipe for electrical issues like yours.
+1 regarding "1 + 1 = 2"
Old May 6, 2011 | 07:03 AM
JAMAMAN's Avatar
JAMAMAN
I would check to see if the battery is good, cause 590 crank amp is s h i t , especially if you have subs and amps. Some folks on this site told me that Interstate batteries are good, and i installed one and it runs perfect.
If that doesnt solve your issue, check the notorious passenger side floor for water. My water leak issue made my HID lights not work either and my dash was possessed including my tail lights. I hope your issue is the battery. Cause the water issue is a b i t c h to fix .
Old May 6, 2011 | 07:14 AM
Ryan™'s Avatar
Ryan™
Banned
are your HID's connected directly to the battery? if so try replacing the battery, if not... connect them directly to the battery.
mrtrodonet
Sep 19, 2020 03:12 PM
drfister
May 3, 2018 10:38 PM
piotrek53
Oct 13, 2015 06:54 PM
yourmom6990
Sep 14, 2015 10:52 PM
zanemoseley
Sep 6, 2015 12:58 PM
