2011 front door subs?
Old Jul 15, 2011 | 04:06 PM
roblee121's Avatar
roblee121
Default 2011 front door subs?
has any one replaced the factory subs in the front door panels in their 2011 mustang? i am looking to upgrade however i am unsure what will fit and sound the best. crutchfield didnt help me out any. so now i as you guys... what ya'll got?
Old Jul 16, 2011 | 01:53 PM
Goldenpony's Avatar
Goldenpony
Don't know if they're the same, but I replaced the ones in my '06 GT with Shaker 500 with the subs from Shelby. Made a little improvment. Look factory.
Old Jul 16, 2011 | 05:08 PM
Mishri's Avatar
Mishri
Mish-ogynist
The 2011's are a lot better than the ones in my 2007, but still not as good as aftermarket, you can look at old threads for the 05+, its really teh same shaker system as those. I believe they are 8" subs, you can put any 8" in there. From what I read putting a better quality amp does more for sound than the subs/speakers though.
Old Jul 17, 2011 | 06:11 PM
Kitzy's Avatar
Kitzy
I powered my stock subs with a Focal Solid 1 amp. Made a huge difference. Doesn't Kicker make the Shelby setup and aren't they the only one with a shallow enough mount that the grille doesn't need to be modified?
Old Jul 17, 2011 | 08:49 PM
hawkeye18's Avatar
hawkeye18
I thought Pioneer made a shallow-mount 8" sub as well?
Old Jul 17, 2011 | 10:53 PM
Souldriver's Avatar
Souldriver
door mounted subs are a horrible idea. its like sitting listening to a sound system backwards where the bass is in front of you instead of below or behind.
for me the problem is balancing out the bass and treble so neither is boomy (bass) or to ice picky (treble) when turned up.
ways to fix this....
new head unit and a real sub
a new head unit can assign those door woofers to not play such low notes so they are doing less and they are staying in their right frequency more (high frequency bass is where they should be) and adding a real 10-12" sub will cover the real low end.
you can replace the head unit only that will also clean things up right away.
or you can put money into an amp that will power what you have now and any future upgrades. it will make things a bit tighter and crisper.
what you have to decide on is what do you want to change and how much do you have to spend on it.
jwog666
Dec 27, 2021 08:09 PM
b8checker
Sep 30, 2015 07:11 AM
Sep 25, 2015 06:58 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
