View Poll Results: Pick your poison
Automatic 5 speed
35
24.31%
manual 5 speed
109
75.69%
Voters: 144. You may not vote on this poll
Automatic vs. manual
#71
I gotta tell ya it's an easy chirp in 2nd even with my auto! Too the floor and nudging 3rd and Your way past 80 mph in an 1/8th of a mile. I think I finally have a car that matches my nickname............................:icon_muscleca r:
#72
#73
Bought GT with manual tranny and immediately regretted it the next day in 20 minutes of stop and go traffic. Stuck it out for a couple weeks and now I would never go back. Every time I get into an automatic, I freak out a bit, looking for the clutch.
#74
#75
#76
But they do have clutches, not torque converters.
#77
#78
if you want to call it that, it's a bit more accurate.
It used to be a common debate on the BMW forum when the M3 came out with SMGII, whether it's an auto or a manual. But they are manual transmissions with a clutch (or two clutches, depending on design). They just don't require a driver to shift them.
Autos have torque converters.
#79
#80
Not quite the same. It's a standard manual transmission, with dry clutch and everything. The car just comes with an extra system that engages the clutch, shifts the transmission, and disengages the clutch, all without driver input.
Dual clutch transmissions, from what I've read, apparently break the transmission down into two splines: one for odd gears and one for even. So while the car is in an odd gear, the even gear clutch stays engaged and already in the next gear, ready to shift over as soon as needed. There is no disengagement time needed for a single clutch to release, then shift, then re-engage. That's how dual clutch transmissions get shift times down into hundredths of seconds without power loss.
