Full throttle voids warranty?
Old 03-15-2012, 08:26 AM
hawkeye18
hawkeye18's Avatar
Originally Posted by Warren3000
I heard from somewhere that new mustangs have a hidden logic in the ecu that going wot for longer than 10 seconds leans out the motor and voids the warranty. Anyone know anything about this?
Your dealer told you this, didn't they.
hawkeye18 is offline
Old 03-15-2012, 08:40 PM
Nuke
Nuke's Avatar
Put that stick down; you'll poke someones eye out.
Put a hat on; you'll catch pneumonia.
Don't drive WOT; you'll void your warranty.
Nuke is offline
Old 03-15-2012, 11:58 PM
Mishri
Mish-ogynist
Mishri's Avatar
Originally Posted by danzcool
I seriously doubt they have an intentional "booby trap". I wouldn't be surprised if some dealers are trying to intimidate people though.
And 10 seconds is a long time to be WOT, assuming you lift between shifts, only the overdrive gears may allow a WOT pull longer than 10.
no 10 seconds isn't a long time at all. the 1/4 mile stock in yours and his car is in the 13 second range. mine would be 12 second range.
Nope whoever told him that is full of ****..
WRONG! totally wrong. no way would they or could they void the warranty for it based on that. Legally they'd have to honor the warranty for a WOT pull in any vehicle... They can't even void the warranty in the GTR for that, although they will if you use launch control in the GTR. but that is an optional mode and it states that warranty wont be covered when using that mode. but that is the only stock vehicle warranty void i've ever heard of.
Mishri is offline
Old 03-16-2012, 01:19 AM
danzcool
danzcool's Avatar
I was just saying if you lift momentarily on gear shifts, then your 1/4 is not completely at full throttle, you'd only be at full throttle through each gear, and at least in my car (right now) the only gear I can stay at full throttle for more than 10 seconds before hitting the redline is 5th... and then only with the speed limiter turned off. (but I'm not quite stock either).
I agree that the statement by the dealer was BS.
Some of the 11+ cars may have a design issue in the fuel rail that expresses itself when WOT for extended times, but they can't void your warranty over it.
danzcool is offline
Old 03-16-2012, 11:28 AM
Mishri
Mish-ogynist
Mishri's Avatar
You wont be running any record 1/4 mile passes if you are lifting
http://en.wikipedia.org/wiki/Powershifting
whats the point of seeing how fast you can go if you are granny shifting?
Mishri is offline
Old 03-16-2012, 11:57 AM
Thrashard340
Thrashard340's Avatar
I can't believe this thread has lasted this long.
Thrashard340 is offline
Old 03-16-2012, 12:52 PM
MrSandman
MrSandman's Avatar
This is the definition of FUD.
MrSandman is offline
4cylinderplus2
10-09-2020 07:45 PM
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
guitarman376
09-30-2015 05:54 PM
junior04
09-28-2015 10:53 AM
Quick Reply: Full throttle voids warranty?
