Thumping or bumping sound from the front of the car...
I'd lift up the front end and give it a good visual inspection on the suspension/sway bar for signs of excessive wear or other issues with a flashlight.
If it made noise a thumping something is obviously hitting something else. If the sound stops I'd be worried whatever was thumping just finally broke.
It's weird for a suspension problem to come and go. The car was smooth as butter on the drive home from the dealer. I felt it a tiny bit on the road where it always seems to start. Out of frustration, I slammed on my brakes and all was smooth again. It didn't even make a peep in my driveway. Sigh.
Jack the car up and take the front tires off. Loosen the top bolts that attatche to the sway bar and apply some lock tight, then crank the bolts down as tight as possible, a quarter turn can make a noise difference. I dealt with this and now noise free.
My 12 model had a similar sound that was really loud over speed bumps and suspension travel........After two visits they replaced the lower control arms. (I kept telling them that's what it was, but they have to be sure in their mine.) Mine was louder when hotter and nothing when it was raining.
Ford has new LCA's with poly bushings out now or sometime soon....
It was doing it at least 80% of the time. Mainly on hot dry days, but they could not replicate the 1st time due to rain.
If it's not all the time it sounds like something different. I wish I could help.... My sound was obvious.... Can you get someone to drive over bump, take video for us and for Ford?
