Noise form gear box ?
2007 Gt 65000 miles
I recently brought my car to form to get this noise fixed
At first they told me I needed a new clutch and the pilot bearing exploded and caused damage to the fingers and clutch and the flywheel was worped and that's what was causing the issue
So I replaced it with a brand new clutch kit from McLeods with a new flywheel
Go to pick up the car and the noise is still there
So the ford trans tech told me now the input shaft bearing is bad and that's what is causing the noise so they replaced the input shaft bearing and I go to pick it up yesterday and the noise is still there
It's been over a month and I already changed parts that I didn't need to and I am looking for help on this issue
I posted last month and couldn't get much
Thanks
Attached is the video of the same noise after a new clutch flywheel and piolet and throw out bearing and input shaft bearing now ford is reaching out to a ford tech to find the issue
Thanks
HTML Code:
http://youtu.be/CZLTu1IATT0
