What's inside
Old Oct 22, 2005 | 11:09 AM
F00Mustang's Avatar
F00Mustang
Default What's inside
I have ordered my '06GT and am planning to run the ZEX setup on it. Does anyone know what the motor is made out of. I'm pretty sure the heads are aluminum, but I need to know about the block and the internals. I'm hoping that the rods, crank, and pistons are all forged.
Old Oct 22, 2005 | 01:58 PM
andyman's Avatar
andyman
Default RE: What's inside
ORIGINAL: F00Mustang
Don't take my word for it, but I'm pretty sure they aren't forged. no no they are Fordged lol
Old Oct 23, 2005 | 03:41 PM
05zexstang's Avatar
05zexstang
you have a steel crank and hyper eutectnic pistons and rods. As far as running nitrous It's pretty safe. This new Zex kit has an active fuel control that adds and takes away fuel to make sure you never run too rich or too lean. Your transmission is strong enough to withstand it also. If you use drag radials or slicks while running No2 I suggest replacing your clutch. It will probably slip, change your flywheel while your at it. Forged pistons and rods wouldn't be a bad addition to your car to make it alot more reliable while running nitrous.
Old Oct 24, 2005 | 02:54 AM
F00Mustang's Avatar
F00Mustang
I'm not looking to run a stupid shot of nitrous, in fact, i'll probably never go any hotter than the zex kit will alow, usually staying with the 75 or 100 shot. Just want to be sure i won't have problems with my engine after using NO2.
Out of curiosity, have you run your car and what did you run.
Old Oct 24, 2005 | 06:58 PM
delurker's Avatar
delurker
Block is aluminum, too.
PaulH2
20
Jan 31, 2016 09:48 AM
GLOCKer
Sep 28, 2015 07:36 AM
Steve@CJPP
CJ Pony Parts
Sep 24, 2015 02:51 PM
maestro1024
Sep 21, 2015 02:40 PM
ccdguy
Sep 19, 2015 05:20 PM
