Bleeding 06 GT brakes ??
In process of bleeding/flushing brakes, front flows fine using my Motive pressure device, but the rear has no flow once the bleed screws are opened. Normal? Is there a valve I need to hold down/open??
All advice appreciated.
This does not sound good. When bleeding S197 brakes there is a sequence according to the shop manual:
1. Passenger rear
2. Driver Rear
3. Passenger front
4. Driver Front
What happens without the pressure bleeder when you open the passenger rear bleeder and press the brake pedal? Is there fluid flow?
1. Passenger rear
2. Driver Rear
3. Passenger front
4. Driver Front
There should be flow, as Scott2 said, have someone press the pedal and open the bleeder. If there's no fluid coming out take the bleeder out completely to make sure the problem isn't the bleeder screw. If there's still no fluid take it to a brake shop. Brakes are not something you want to mess with unless you know exactly what you're doing.
Also, as Scott2 pointed out, there is a correct sequence to follow for future reference.
