Door Panels?
Old 08-27-2018, 10:45 AM
Grouper
Grouper's Avatar
Question Door Panels?
What is the best glue for the famous door panel inserts 2008? Thank you
Grouper is offline
Old 08-27-2018, 01:26 PM
8 ball
8 ball's Avatar
I've used the 3M Upholstery Spray glue, and it lasted about 8 months. Most recently, I tried the Woodward Contact Cement (brush-on) that is featured in a video on this site, and it looks like it won't last a month. My next step will be to take it to an upholstery shop, and if that doesn't last, there are some plastic inserts that I will install: (video linked)
8 ball is offline
Old 08-27-2018, 01:55 PM
Grouper
Grouper's Avatar
Thanks for the response, I used one of those videos that recommended Permatex Heavy Duty Headliner and Carpet Adhesive it don't last very long either.
Grouper is offline
Old 08-27-2018, 02:16 PM
Derf00
Gentleman's Relish
Derf00's Avatar
There's a whole thread about this here....
https://mustangforums.com/forum/2005...gging-fix.html
Personallyl, ANY leather or vinyl material will peel off over time. The reason is that the materials expands and contracts with temperatures. That constant shifting causes the material to eventually pull away from the door. My 2008 just started to lose adhesion. I'll be doing what I did for our 2006 escape that had the same issue, pulling them off and replacing them with a cloth insert. Cloth doesn't have the same issue as the vinyl/leather and the adhesive also soaks in a bit to the backside of the cloth so that further enhances the grip.
Derf00 is offline
Old 08-27-2018, 03:19 PM
artsvettes73
artsvettes73's Avatar
The most important thing is cleaning the old insert. The foam has broken down and it needs to be completely clean. If you just spay glue on it, expect it to come off again because the foam continues break down.
artsvettes73 is offline
Old 08-27-2018, 03:25 PM
Grouper
Grouper's Avatar
I agree, I wire brushed all the old stuff and cleaned with lacquer thinner as it cuts about everything and let it dry for a long time before I proceeded.. Thanks On the SVE door kit I couldn't find it on their site and it had a lot of bad reviews. They might not have them any more....
Grouper is offline
Old 09-05-2018, 08:12 AM
algregory
algregory's Avatar
My brother an extremely gifted car buff told me to use Phenoseal Vinyl Adhesive Caulk goes on white, dries clear.
Clean up the old stuff, spread this stuff on and press into place. Good thing is that it is water soluble so clean up is a breeze you can get it right to the edges without worry. I did mine over a year ago in the hot and humid climate, the cold and humid climate of North Carolina and it is still holding on my '05 GT.
FYI, he uses this stuff for a lot of "car stuff" and even used on the "logos" or whatever you call them the may be attached to the wheel hubs, and they stay stuck years later. a very versatile product. FWIW
algregory is offline
Old 09-05-2018, 08:51 AM
Grouper
Grouper's Avatar
Thanks a bunch!!!
Grouper is offline
Grouper
11-06-2017 01:13 PM
0NF1R
32
03-26-2014 09:01 PM
Fifthwind
11-21-2013 10:41 AM
spencer.page
07-14-2011 07:24 AM
JamesNorman
03-28-2009 10:14 AM
Quick Reply: Door Panels?
