12v Switched
Old Nov 29, 2005 | 12:23 AM
donnyonee's Avatar
donnyonee
Default 12v Switched
Lookin for a 12v switched in the engine bay or in the cabin other than the fuse box, tried PCM Fuse, but spit out a P1633 KAM Volt Low code
Old Nov 29, 2005 | 12:46 AM
spyder7724's Avatar
spyder7724
Default RE: 12v Switched
i couldn't find one so i ran a wire from the inside fuse box(pass side kick panel) out to the engine bay for my e-h2o pump. i als ran 6 more wires out for future components cause it was a pain to do it neatly. there is a fuse position that is left blank in the fuse box. i made a terminal end that would fit that slot and ran the wire out the grommet through the kick panel (pass side) and behind the inner fender and up behind the washer tank. you can't see any of the wires i ran. i took me 2 hours though but looks factory.
Old Nov 29, 2005 | 12:50 AM
donnyonee's Avatar
donnyonee
the small door pops open nicely, how do you remove the kick panel?
Old Nov 29, 2005 | 12:52 AM
spyder7724's Avatar
spyder7724
the trim along the scuff plate area just pops up with a little persuasion. then the same for the kick panel. i don't remember any screws at all. it's been a month or so now since i did that.
Old Nov 29, 2005 | 10:43 AM
donnyonee's Avatar
donnyonee
im lookin there, thanks, don
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
unit91
Sep 15, 2015 09:53 AM
