CAI & Check Engine Light
My wife got me a MAC stainless steel straight shot air system GT version for Christmas. I installed it in my 2005 mustang and it all went smoothly as this is a very simple install. Well after driving for a bit the check engine light came on. I checked all my clamps and the screws for the air flow sensor and tightened a bit and reset the check engine light. Well sure enough the light came back on after a few miles. I don't have a programmer yet so I took it to a parts store and had them check the codes. Basically I was getting 174 and 171 error. Meaning it is running lean. I would expect this to be the case if it is getting more air but I guess I kind of thought the internal computer would adjust for that. Do I need a programmer like the Diablo Predator to get around this check engine light problem. I plan on getting a programmer anyway but wanted to know if I might have another problem with the MAC that I installed.
Thanks
Thanks
RE: CAI & Check Engine Light
You need to get the Computer flashed... And Yes that means you need A Diablo Preditor or SCT ,,,, there are many products that you can use to adjust the fuel ratio mixture since adding a CAI. I would get it done asap so you can get the performance the cold air induction gives you. There maybe a speed shop in the area you live in that has a dyno they can flash it and re-calibrate for peak results...
I've got a K&N CAI on mine and had the same problem. From everything I've read, you definitely do need a tune. I've got mine on the way from Brenspeed (delivery on Jan 4). I contacted K&N before I ordered the tuner though and they said to disconnect my negative battery cable for 1 hour. I've had no problems since and it's been over a month. One thing I noticed when I did this is that before I disconnected the cable and w/ the check engine light one I was getting 20.3 mpg. After the fix, it dropped to 19.5 mpg. Seems the cars computer adjusted just fine w/ only the CAI on. Definitely get a tune though.
Thanks for the responses. I guess I was pretty sure I needed the programmer but I was told by some people that I shouldn't need to flash from just installing a CAI. They told me the internal computer would adjust for the extra air coming in. I have ordered my diablo predator.
Thanks
Thanks
ORIGINAL: maverick9576
Thanks
Thanks
