Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
URGENT!!!
Old Jul 17, 2007 | 12:51 PM
fullsteedahead's Avatar
fullsteedahead
Default URGENT!!!
OK LYESTERDAY II STARTED CHANGING OUT MY BRAKE PADS TOOK US ALL DAY TO NIGHT LOL LIKE 6 HRS BUT THEN WHEN WE TRY TO BLEED THEM TO MAKE PRESSURE BUILD UP IT JUST LEAKS BRAKE FLUID WHEN U OPEN THE LITTLE VALVE ON THE CALIPER
WHEN I PUMP THE BRAKE IT STAYS SMOOTH AND NOT HARD
DOES ANYONE KNOE OR HEARD OD OF THIS?
Old Jul 17, 2007 | 09:08 PM
chewie's Avatar
chewie
Default RE: URGENT!!!
Dude, are you drunk posting?
Old Jul 18, 2007 | 12:32 AM
Stone629's Avatar
Stone629
wow
Old Jul 19, 2007 | 01:51 PM
fullsteedahead
you guys are ********
i need help not smart *** remarks
Old Jul 19, 2007 | 04:34 PM
Stone629's Avatar
Stone629
It's supposed to leak brake fluid when you open the valve and depress the brake pedal. Are you keeping the pedal depressed while whoever is helping you closes the valve. If you let up on the pedal B4 tightening the valve it will suck air back into the brake line causing squishy brakes.Also keep checking your fluid level.
1. Press Pedal and hold while someone opens valve
2. Once pedal goes all the way to the floor, hold it there until you helper tightens valve.
3. Let up on pedal once closed.
4. Repeat on all calipers until brakes feel right.
5. Keep a check on fluid level and keep adding fluid as needed.
Hope this helps and sorry for being an *******.
Old Jul 20, 2007 | 05:23 AM
chewie's Avatar
chewie
ORIGINAL: fullsteedahead
Maybe you should re-read your initial post before you get all "butt hurt". Just a suggestion but, try spell check,think about what you want to post, write it, read it,and leave the caps lock off before you post.
You didn't get smart *** remarks, but appropriate responses to the illiterate abortion you put up.
Old Jul 20, 2007 | 05:48 AM
grey03mach1's Avatar
grey03mach1
I've changed my pads twice since I've owned my mach and never had to bleed the brakes.
Old Jul 20, 2007 | 12:50 PM
code3GT's Avatar
code3GT
Mustang Nazi
ORIGINAL: chewie
chewie is in the house...LOVE ya bro.
dabsevo
Dec 16, 2013 02:12 PM
be2019
Feb 11, 2009 01:08 AM
be2019
Feb 10, 2009 12:03 PM
Car_Ramrod
Jan 2, 2007 08:19 PM
BlackGTCoupe
Apr 5, 2006 12:09 AM
