Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
spark plugs
Old Mar 5, 2008 | 10:49 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default spark plugs
does anyone have any info on spark plugs? like:
what is the best?
what makes it the best?
how much are they?
which ones do you use?
Old Mar 7, 2008 | 11:51 PM
rygi23's Avatar
rygi23
Default RE: spark plugs
well you had 0 replies so I thought I'd help a brother out. I've always used whatever doesn't cost that much b/c every guy behind every counter says they're all the same. Autolite isgenerally what I use and have never had a foul one or anything like that. Also, I've never heard anyone say they've found one is significantly better than the other. I even had a fellow racer at the track tell me SplitFire plugs slowed his car down a tenth. It's all hogwashso just get whatever's reasonable. Hope this helps.
Old Mar 8, 2008 | 12:07 AM
USMCrebel's Avatar
USMCrebel
..... damn, i guess it really doesnt matter one a 99% stock motor does it, its when you need more bigger spark.
Old Mar 8, 2008 | 08:57 AM
5speedstang's Avatar
5speedstang
NGK TR-55 ix are a very good plug. smooths out the idle alot. but the only thing is there like 8 bucks a pice. for a half of a heat range cooler you can go with the TR-6 which alot of guys like to run. they are about 2 bucks a pice. i think im gunna order the tr-6 in a few. my dad runs the NGK TR-7s in the nova and he loves em.
Old Mar 9, 2008 | 11:48 PM
groundpounder's Avatar
groundpounder
Sith Lord/Site Mod
ORIGINAL: USMCrebel
BINGO, rebel! Don't waste your money on $8 plugs, GMS coil packs, MSD boxesor any of that stuff on a largely stock engine.
Old Mar 11, 2008 | 03:18 PM
DesertMach's Avatar
DesertMach
Actually I was just talking to a mechanic from PSR (performance solutions racing) this last weekend at or club day out at the track, He was telling me not to use platnium plugs in our cars because they burn to hot, (he may have ment for our AZ heat), He was also telling me about one of our Mach buddy's that took his Mach in for a dyno, the first thing they did was a base line dyno, then they changed the plugs (NGK TR55 gapped at .040) and did another dyno. He told me they picked up almost 8 hp just from changing the plug and smaller gapping.
I know it sounds unlikely, but im sure alot of you are familair with the M1R and if you are you probably have heard of PSR and alot of the parts testing they do on their dyno. I myself think its pretty awesome the research they do for us.
OFF TOPIC- there is a read over there about a Dyno testing they did with stock intake vs. polish intake vs. with and without the PHP/Roy intake spacer. they used the same car for every test they said the car never came off the dyno while swapping parts.
Old Mar 11, 2008 | 03:38 PM
USMCrebel's Avatar
USMCrebel
desert, im on there to, but i cant find that link...do you have it?
Old Mar 11, 2008 | 06:21 PM
jmac72187's Avatar
jmac72187
corner carver
ORIGINAL: USMCrebel
+1
I would love to read about the intake testing.
Old Mar 13, 2008 | 02:44 PM
DesertMach's Avatar
DesertMach
I just found out it was deleted as to there were some people arguing about who had ported the intakes and such ill see if I can fing a like about the tests on another local site here
Old Mar 13, 2008 | 02:55 PM
DesertMach's Avatar
DesertMach
http://www.stangology.com/forums/ind...showtopic=2182
This site has the test results also with the dyno graphs, you will need to be a member to see this section.
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
lmurf60
Sep 24, 2015 10:07 PM
