Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Normal???
Old Apr 21, 2008 | 07:25 PM
stang1101's Avatar
stang1101
Default Normal???
My Mach iscurrently in storage, but I took it around the neigborhood for a little run. For the first couple shifts into 2nd it doesn't want to ingage and gind of grinds,but after about 5-8 minutes the shifts into 2nd become smooth as butter. Is this normal, because if something goeswrong I have a warranty to cover the tranny.
Old Apr 21, 2008 | 08:10 PM
jmac72187's Avatar
jmac72187
corner carver
Default RE: Normal???
That is normal with 3650's, but it isn't a good thing. A clunk into 2nd is normal but not full out grinding. This leads to bad synchros. I would complain and try to have them rebuild it. This happens a lot in cold climates.
Old Apr 21, 2008 | 08:59 PM
rygi23's Avatar
rygi23
Thought I read somewhere in a thread a bit back that there was a TSB on the issue and that a simple solution was less fluid. Maybe someone could chime in on this?????
Old Apr 21, 2008 | 09:44 PM
whodini72's Avatar
whodini72
Hell every modular mustang ive driven has a "clunk", we all know the stock shifters are horrible, but I'd drive it for a day or 2 and see how it goes, dont panic just yet
http://users.igl.net/whodini/mach101.jpg
Old Apr 22, 2008 | 03:01 AM
Subotai_95's Avatar
Subotai_95
Hmmmm.. I know there is a TSB on bad 2nd gear synchros for the 3650 equipped stangs.. But the guys are right, it shouldn't be grining into 2nd like that. When you're stopped try putting it in 2nd and try getting going from a stop that way. If it grinds or throws the car out of gear the synchro is going bad. If it's still smooth as butter after a bit I wouldn't worry about it TOO much until it starts doing that all the time. Might be something you could complain about to the dealership though if you still have a warranty on it though brudda.
Old Apr 22, 2008 | 06:34 AM
stang1101's Avatar
stang1101
Does anybody have the actual Tsb page so if I go to the dealer I have some evidence.
Old Apr 22, 2008 | 08:32 AM
jmac72187's Avatar
jmac72187
corner carver
The recommended fix for this is changing your tranny fluid to 3.2 Quarts of Dexron ATF or something like that. When I first got some colder weather, the car would clunk into second gear on the first shift when the car wasn't warmed up. I replaced the tranny fluid and it smoothed it out a bit. I would try that and if it doesn't work then just bring it in under warranty.
Old Apr 24, 2008 | 08:23 AM
Subotai_95's Avatar
Subotai_95
ORIGINAL: stang1101
https://mustangforums.com/recalls-an...042613/TSB.htm
That's from the TSB link at the top of the MF page, regarding the T-3650, which if you're stock, would be the tranny you have. That ones about 1st / 2nd gears clashing and difficulty shifting. Don't know if that will help brudda, but if you want to look through the rest of them, most of Ford's TSB's from '04 are on that page up there.
Old Apr 24, 2008 | 09:35 AM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
there is also a TSB on 3rd......i should know just had the dealer ship upgrade all my pieces to BILLET, this bitch aint breaking now!
Old Apr 24, 2008 | 05:17 PM
wakin3722's Avatar
wakin3722
It could possibly the transmission fluid have settle at the bottom.
FivePointToTheOh
Mar 9, 2020 10:26 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
96stang3.8
Sep 10, 2015 06:42 AM
