Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
powder coating
Old May 4, 2008 | 12:52 PM
.boB's Avatar
.boB
Default RE: powder coating
450* until the powder melts; usually 4-5 minutes. Then 400* for 20 minutes. If you leave it in too long, it will burn and darken.
Small/thin parts I just prep, coat, and bake. But bigger parts - like heads, manifolds, bellhousing - I pre-bake them at about 150*-200* to get the metal warm to the core.
From prep to install is usually less than 1 hour.
Old May 4, 2008 | 08:51 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
so before you bake them you pre bake them then coat and bake again?
Old May 5, 2008 | 12:03 AM
.boB's Avatar
.boB
Yeah, big parts like heads take a lot of time to warm up. You'll get better powder adhesion if it's a little warm to begin with. Otherwise, the mass will transmist the heat energy without heating the surface well. The powder heats and melts, but the surface isn't warm enough.
Small parts don't require that.
jwog666
Dec 27, 2021 08:09 PM
Granatelli Sales
Jan 20, 2020 12:34 AM
b8checker
Oct 8, 2015 12:55 PM
Oct 1, 2015 09:29 AM
b8checker
Sep 30, 2015 07:11 AM
