Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
89 octane???????
Old May 21, 2008 | 08:37 PM
rygi23's Avatar
rygi23
Default 89 octane???????
would using 89 octane hurt our machs our just decrease the performance? I'm sure y'all know the motive behind the question! Fill a brother in please.
Old May 21, 2008 | 10:41 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
Default RE: 89 octane???????
it can work in it, but you will damage your engine eventually......you know my dad had some friends in highschool and college that kept white lightening around for when they ran out of gas
Old May 21, 2008 | 10:44 PM
03MachMe's Avatar
03MachMe
yea it will work but after a while you will damage the motor if you really want to do that then just get an SCT or something and have a shop do an 89octane tune for you then you will be just fine
Old May 21, 2008 | 11:21 PM
Shaken's Avatar
Shaken
Personally I would not use it the Mach 1 has a 10:1 mechanical compression ratio which I believe needs 91 octane minimium.
Old May 22, 2008 | 12:16 AM
USMCrebel's Avatar
USMCrebel
^ correct
Old May 23, 2008 | 10:20 AM
NotStok's Avatar
NotStok
I refuse to run anything under 93 Octane in my Mach for the simple fact that we have this "Gasahol" crap in my state (10% ethanol). Premium is like $.14 more expensive, but i'm attempting to make up for being forced to run on the swill theyre selling here.
Old May 23, 2008 | 10:22 AM
USMCrebel's Avatar
USMCrebel
we have the same thing here man, i hate it.
Old May 23, 2008 | 10:34 AM
Shaken's Avatar
Shaken
I still use 94 ultra smells the best with th o/r pipe it only 8 cents more where I buy fuel.
Old May 26, 2008 | 04:10 PM
MachWon04's Avatar
MachWon04
I know you can do lean/econo tunes with the SCT tuner (can the diablosport do it as well?), could you get a tuner and run a lean tune and retard the timing and such and be able to run 87 or 89 octane? I'm pretty lost as far as tuning is concerned but would that be a possibility? My mach drinks gas
Old May 26, 2008 | 04:58 PM
xxkazp3rxx's Avatar
xxkazp3rxx
Our cars have to run minimun 91 Octane which is premium, while 93 is considered Super Premium.
If you run anything under 91 Octane not only can you cause your motor to be harmed, it will also cause lower gas milege and it won't burn as efficient.
Spend the extra 1.50 a tank of gas to run the 91/93 (as available)vs. the 89... if you can't afford it - you can't afford your car.
msavoia23
12
Jul 7, 2018 12:08 PM
Big Al's 03
Sep 15, 2015 09:05 AM
MasterLanMan
Sep 13, 2015 08:21 PM
Sandmanbjj
Aug 21, 2015 12:38 PM
dragman72
Aug 9, 2015 12:54 AM
