Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
intake silencer delete
Old Jun 20, 2008 | 01:57 PM
sixty5mustang289's Avatar
sixty5mustang289
Default intake silencer delete
is this an effective mod for making power or will it be a waste of my time? I read about it on M1R but I am skeptical about stuff like that. Has anyone done it? Power gains?
Old Jun 20, 2008 | 02:09 PM
DaMach04's Avatar
DaMach04
Default RE: intake silencer delete
its more of a waste of time than anything else. i did it tho, when i had a stock intake. its very easy, just go to your local hardware store and geta plug to fit the hole.
the type of plug i used was one with two round metal plates with a pice of rubber sandwiched between. with a bolt thru the middle, as you tighten the bolt, the plates tighetn down on the rubber between and make the rubber bulge out (like squeezing a sandwich and watching the contents fall out) the rubber bulging out seals up the hole.
edit: I also raised my shaker, but when i had the new motor installed i think they put it back to stock height.
Old Jun 20, 2008 | 02:23 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
it doesnt do anything, cept allow more airflow.
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
