Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Is this normal?
Old Jul 4, 2008 | 12:20 AM
sixty5mustang289's Avatar
sixty5mustang289
Default Is this normal?
Is it normal for an '03 Mach 1's parking brake light in the guage pod to come on during hard braking? Every time I have to brake hard the little red indicator light in the guage pod comes on like when your parking brake is up. Something wrong in the wiring? Loose cable?
Old Jul 4, 2008 | 01:14 AM
03MachMe's Avatar
03MachMe
Default RE: Is this normal?
no its just telling you your abs is working i think i have seen mine i think once when i had to slam on my breaks but just that once am i right guys?
Old Jul 4, 2008 | 07:20 AM
ponysnake99's Avatar
ponysnake99
Low brake fluid, light doubles as low brake fluid light.
Old Jul 4, 2008 | 09:01 AM
cesar5571's Avatar
cesar5571
Ditto... The fluid shifts when you brake hard and the sensor momentarily detects low. I had the same thing happen, and after I added fluid to the fill line, it stopped.
Old Jul 4, 2008 | 10:26 AM
Subotai_95's Avatar
Subotai_95
Double ditto.. lol Mine did the same thing when the brake fluid got low, and a couple of times under hard breaking. I'd check the fluid just to make sure it's not low and if it's not I wouldn't worry about it unless it does that all the time broham..
Old Jul 4, 2008 | 01:10 PM
sixty5mustang289
I appreciate the help guys.
Old Jul 4, 2008 | 11:07 PM
mustangman02232's Avatar
mustangman02232
dont add brake fluid, if your BF is low its cause the pads are low and the pedal is getting replaced with fluid
Old Jul 5, 2008 | 02:47 AM
Subotai_95's Avatar
Subotai_95
^^^Ehhhmmm what exactly are you talking about? The pedal being replace with brake fluid?? I'm not throwing the BS flag here, but that makes absolutely no sense.. When the pads get low the screecher bars in the pads tap the rotors when you hit the brakes hard, hence the screeching sound.. If his fluid is low the pedal will feel loose and he'll have to mash the pedal down in order to stop because there isn't as much pressure in the line. Is this what you mean??
FivePointToTheOh
Mar 9, 2020 10:26 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
96stang3.8
Sep 10, 2015 06:42 AM
