Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Trac-control, ABS issues
Old Aug 5, 2008 | 11:56 AM
Kenny_k82's Avatar
Kenny_k82
Default Trac-control, ABS issues
Ok, got the 04 mach 1 and the trac control was working fine. That was only a week ago.. now when I start the car the green trac light flashes stays offand the trac light on the console stays orange... if I push the trac button it just stays orange and the green in dash trac light never comes on. Also, the ABS light is stuck on... Any simple ideas on what to do? I checked the fuses under the dash but have no guide to what goes where in the power dist. box under the hood. I have noticed other stang owners with trac-control having issues as well but no answers!
Old Aug 5, 2008 | 12:08 PM
darkmach1's Avatar
darkmach1
Default RE: Trac-control, ABS issues
yea take it to the dealer ASAP, simple and easy.
Old Aug 5, 2008 | 12:15 PM
Kenny_k82's Avatar
Kenny_k82
Can't just take it back to the dealership I bought it from cause it's like 500mi away. You said simple and easy, is it a simple and easy fix? Any idea on whats actually causing the problem or what it might cost?
Old Aug 5, 2008 | 12:36 PM
darkmach1's Avatar
darkmach1
Is it under warranty? I would never buy a used car without extending the warranty, if it does take it any dealer it doesn't matter. I imagine they will have to go into the ECU and reset whatever it is thats causing the problem.
Old Aug 5, 2008 | 12:37 PM
darkmach1's Avatar
darkmach1
in the manual it says if that light turns on and stays on take the car to the dealer ASAP.
Old Aug 6, 2008 | 01:05 PM
DesertMach's Avatar
DesertMach
I haveread about this issue on several other Mach'sbefore and it turned out to be one of the abs sensors on the wheels, these sensor affect both the trac loc and the abs.
cr620
Oct 3, 2022 10:18 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
ChampInSD
Oct 2, 2015 04:55 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
