Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
Mods, need help
Old Nov 22, 2008 | 08:18 PM
rygi23's Avatar
rygi23
Originally Posted by nikbait
I've read, not personally done, that if you're gonna upgrade your TB, then you should do more mods to make it worthwhile. The new TB's are very expensive, like you're seeing, and I've heard won't do much in the way of increasing hp unless you do more mods.
Thx bro. $390 is three hundred ninety bucks!
Old Nov 22, 2008 | 08:33 PM
nikbait's Avatar
nikbait
No prob
Old Nov 22, 2008 | 11:54 PM
GTRACER88's Avatar
GTRACER88
Originally Posted by rygi23
thx a bunch for your feedback. 3 quick questions for you, if you have the time. Have a JLT rai, uses stock MAF...your MAF will bolt right up? LCA and UCA hurt your driveability at all? Accufab is $390...gains less than much cheaper UDP? Much much appreciated.
I have 3 answers.
1. Yes
2. No. Imagine you are running on wet grass. Try running as fast as you can with tennis shoes. You will slip. Now try running with soccer cleats. Thats the difference.
3. Yes. You will notice the UDP more. FYI, UDP does not give horsepower. It just releses parasitic loss. It makes it lighter freeing up HP.
4. A cheaper route for a TB look at the BBK 78mm. Its a TB/ Plenum combo. Its $280
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
TimeLord101
Oct 1, 2015 06:40 AM
firecoyote
Sep 27, 2015 02:37 PM
