Mach 1 Section This section is for discussions relating to the reincarnation of the Mach 1 trimline.
surprising race
Old Dec 22, 2008 | 12:10 AM
grif62's Avatar
grif62
Default surprising race
My friend and I were hanging out and decided to race each other. He has a mustang gt its has exhaust, intake ,tb, and a tuner I believe, and thats all i know of. Its also a 5 spd. I have an automatic, magnaflow, h pipe and tuner. We raced from a 40 roll and barely beat him, not even a car length. What u guys think?
Old Dec 22, 2008 | 12:12 AM
GTRACER88's Avatar
GTRACER88
Well you have 40 hp over him stock. Your car breaths better. Sounds right.
Old Dec 22, 2008 | 12:31 AM
03MachMe's Avatar
03MachMe
the fact he is a 5spd helped him too if you were a 5spd you prolly would have pulled a lil more
Old Dec 22, 2008 | 08:08 PM
rygi23's Avatar
rygi23
sounds right. To be modded evenly, get the intake and throttle body. Your auto will pull from his 5spd more.
Old Dec 22, 2008 | 09:33 PM
USMCrebel's Avatar
USMCrebel
Mach I Section Moderator
have you tuned your shift points yet?
even as an auto, you still shoulda had more on him
Old Dec 22, 2008 | 09:41 PM
Stone629's Avatar
Stone629
I agree with USMC. You should of pulled harder, especially from 40mph. Thats a good spot for our automatic Machs to hit 2nd gear with some RPM already built up and pull hard. Your mods are enough to get you a 13.0. That GT should be higher 13s, maybe a mid 13 on a RARE glory pass.
Did your car drop down to 2nd? If not, next time downshift it manually. Sometimes mine won't kick down like I want it to. Just wondering if yours came out of OD, but stayed in 3rd gear. That would've been enough to keep him within a car length of your Mach.
Old Dec 22, 2008 | 10:22 PM
USMCrebel's Avatar
USMCrebel
i've never tried it in a performance auto before, but in my wife's jetta i hold the brake and build the rpms and get in the jetta range....kinda brake boosting without the turbo
Old Dec 24, 2008 | 05:18 PM
grif62's Avatar
grif62
No, not yet, but he told me he had heads and cams though. And also I just put in the Jlt RAI intake today and im saving up to get a intake spacer and maybe a throttle body idk. But for christmas im getting LT headers woot. Then im going to save up for a dyno tune.
Merry christmas guys.
Old Dec 24, 2008 | 09:00 PM
defconfire's Avatar
defconfire
I would think that with heads + cams + the transmission advantage he should have been able to take you down.
You should definitely get a tuner and up your shift points a couple hundred rpm.
Old Dec 24, 2008 | 11:26 PM
Stone629's Avatar
Stone629
Heads and cams change things a bit. That race sounds a lot more accurate now. Good run Grif, you definitely had your hands full.
Merry Christmas.
